edhunter Posted November 30, 2007 Share Posted November 30, 2007 Found these mounts in my new speedway motors catalog, wondering if anyones used them in the Z.. looks like they'd make an easy swap? http://www.speedwaymotors.com/p/3274,405_SandB-Ford-Motor-Mounts.html?itemNo=ford%20mount%20engine OR these with some modifications... http://www.speedwaymotors.com/p/1376,1152_Ford-Weld-In-Motor-Mounts.html?itemNo=ford%20mount%20engine How about this for a tranny mount? This is a straight one, they also make them in 2",4",6" drop versions... http://www.speedwaymotors.com/p/3279,443_Straight-Tubular-Transmission-Mount.html?itemNo=ford%20transmission%20mount Just started planning a V8 swap, looking for parts and pieces.. Quote Link to comment Share on other sites More sharing options...
ron adams Posted December 1, 2007 Share Posted December 1, 2007 i buy that type of motor mount from heidt rod shop 7 years ago. nice clean design. I built a simular transmission mount. Quote Link to comment Share on other sites More sharing options...
rudypoochris Posted December 2, 2007 Share Posted December 2, 2007 I don't know about the second and the third pieces, but the first just looks like standard late 60's motor mounts. I am using them in my 240z. The only difference appears to be that those cost $55 each and at Kragen they are under $6 each. Sounds like a raw deal. I would advise search for "Alsil" who designed a cross member that uses those or similar mounts for the 240z. It seems most of us use that setup. Also it seems most use the JTR transmission cross member for a Chevy V8 and then simply drill another hole for it all to line up. Quote Link to comment Share on other sites More sharing options...
