streeteg Posted December 3, 2007 Share Posted December 3, 2007 So, I got the car all together and semi running other then some TPS issues which will probably be in another thread... Regardless I need to put the sender somewhere it can be grounded without bootlegging (fitting in a hose thats grounded) So I have to tap somewhere... My queston is... can one of these two be moved? It looks like the red is the stock sender and the other may just be a ground.... but that wouldnt seem right being that there is a ground right next to the two tapped holes..... Heres a pic for reference... Quote Link to comment Share on other sites More sharing options...
Evan Purple240zt Posted December 3, 2007 Share Posted December 3, 2007 The one with the single wire is for the factory water temp gauge. The other one is the one the ECU uses (red). Evan Quote Link to comment Share on other sites More sharing options...
streeteg Posted December 3, 2007 Author Share Posted December 3, 2007 So I can pull out the black one and replace it with the autometer sender/ use the stocker for the autometer sender? thanks for the quick reply! Quote Link to comment Share on other sites More sharing options...
SR240Z Posted December 3, 2007 Share Posted December 3, 2007 yes you can, weve done it no every swap so far. Quote Link to comment Share on other sites More sharing options...
streeteg Posted December 3, 2007 Author Share Posted December 3, 2007 I can replace it or use the stocker? Quote Link to comment Share on other sites More sharing options...
Evan Purple240zt Posted December 3, 2007 Share Posted December 3, 2007 I replied to your post on nico.. Can't use the stocker. Quote Link to comment Share on other sites More sharing options...
