15" wheels
Guest ottocycle
I am running a 15 inch by 7 inch wide wheel with a zero offset under my stock wheel wells and haven't had any problems. You should be able to go with a 4 1/2 inch offset and not have any problems with it. On my racing Z, I run a 15 by 8 inch rim. But it came with flairs aready on the car. So I can't say for sure, but I don't see any problems with it. Check the search engine and see about any posts on the subject. smile.gif
Guest ottocycle
Anyone running aftermarket 15" wheels? I'd like to go with 15x8's with a 50 - 60 aspect ratio tire. Would I run into clearance problems with the stock suspension set up? I've searched the forum, but have only found similar questions concerning 16 or 17" wheels. My plan for my 77 280Z is kind of a vintage scca look, so I need a relatively small wheel with a relatively large sidewall tire.
Thanks in advance.
Laters,
Chris
