David87LS Posted December 24, 2007 Share Posted December 24, 2007 My headlights are in the high beams on regardless of the position of the switch. I wiggle the switch and notice no flickering so I am not compelled to think it is the switch. I went to the FSM and discover a thing called a "combination switch" which by the looks of it looks like a relay. But where is this switch located. The troubleshooting page refers to this switch if the symptoms are as I am experiencing. Any helpers out there? Oh and where can I get one of these switches? Quote Link to comment Share on other sites More sharing options...
whew41 Posted December 28, 2007 Share Posted December 28, 2007 It mat be your lighting relay or your lighting switch depending on the following: Realy test high beam comes on when lighting switch is set to 2nd position (H) (L) terminals of harness connector with test lead. Switch test High beam comes on when (5), (6), (7), (8) and (9) terminals of harness connector to combination switch are connected witb test lead Quote Link to comment Share on other sites More sharing options...
David87LS Posted December 28, 2007 Author Share Posted December 28, 2007 Do I need to pull the steering column to to perform the tests or is the harness accessible from under the dash. Where would I locate the relay, that is where I will start? Quote Link to comment Share on other sites More sharing options...
Guest durableswedish Posted December 28, 2007 Share Posted December 28, 2007 mine does this too. when you take the cover off that is behind the wheel (4 screws) the relay behind it has a metal leaf that is bent too much and the gap keeps the high beams on. I just jammed a little piece of metal in between it to complete the circuit and it keeps the high beams off. A better thing to do would be to take that metal piece off and bend it back to its original position to touch the other piece of metal...hope that helps! Quote Link to comment Share on other sites More sharing options...
David87LS Posted December 29, 2007 Author Share Posted December 29, 2007 Well I guess I know what Im doing tomorrow morning! Thanks for the lead, sounds pretty easy. I will get back on the status of this tomorrow. Quote Link to comment Share on other sites More sharing options...
