KA24/RB30E Flywheel comparison = same?
Marmo.
hey guys im new to this fourm, thought i'd post a bit about my self, my name is Trevor, im 20yo guy from melbourne Australia, im a tig welder by trade, love cars (mainly holden vl commodores, vettes and 240/260zx's) and in need of a new flywheel/clutch
im looking at one from KA24de to put into my car its an rb30 with r33 rb25det gearbox behind it.
the non turbo rb30e comes with the same flywheel as rb20/25/26
this is the info i have found if some one could fill in the blanks please
Gearbox input shaft both 24t x 25.6mm
clutch disk both 225mm outside daimeter
pressure plate both 6 bolt mounting
Flywheel both 6 bolt mounting ( but unsure if the PCD is the same?)
Flywheel Teeth for starter motor: UNKNOWN at this stage????
Flywheel OD: UNKOWN?
this is the packege im looking at, are these ok or not so good lol?
http://cgi.ebay.com/ebaymotors/F1-STAGE-3-CLUTCH-RACING-FLYWHEEL-91-98-240SX-KA24DE_W0QQcmdZViewItemQQcategoryZ33730QQihZ005QQitemZ150200297084QQrdZ1QQsspagenameZWDVW
so pretty much to sum up everything is an ka24de flywheel exactly the same as what comes on rb20/25/26?
Regards Trevor :)
I can't answer the KA24 flywheel question but I can tell you that a L6 and RB flywheel will interchange as I have RB flywheel on the back of my L28 engine (well I will have once I complete the rebuild). I am using the larger RB25DET type flywheel which has a 240mm clutch. They have the same 6 bolt PCD.
