How do I wire this thing? HELP!
Hey all I have a 283 sbc in a 75 280z. I thought if anywhere could help me out it would be here. I have a HEI distributer, a one wire alternator with reg built in. Can anyone give me a ny pointers on how to wire this thing up without tearing all the factory wireing out? Please help.
  • Administrators
On the HEI cap is a terminal labeled "Bat". This needs to have a good 12v source in start/run. Another terminal will be labeld "tach"... goes to the blue tach feed wire.
A one wire alternator... um, wire it to the positive side of the battery with appropriate gauge for the amperage.
The above is an abridged edition. If you want more detail, feel free to support JTR by purchasing the conversion manual... https://shell7.tdl.com/~jags/OrderingBooks.html
....or feel free to use our built in search engine. It finds posts like this... http://forums.hybridz.org/showthread.php?t=81825
http://forums.hybridz.org/showthread.php?t=125970
Also, no one can respond to you in the members projects forums. I moved your thread the appropriate sub-forum.
Agreed. The manual is your best bet and then the forums. Good luck.
Davy
