czecho Posted January 14, 2008 Share Posted January 14, 2008 I'm dropping in a single turbo 1uz-fe in a 1990 z32 and was wondering would i see a performance drop at all if i used SMIC for it instead of FMIC. Front mount are more expensive and they block radiator, ac-condenser, etc..., if i use the side mounts then my radiator etc would cool my engine better and my side mounts would still be getting cooled the same. I was just wondering because of the excess piping that it might drop performance a lil. but i have no clue at all Please help me Quote Link to comment Share on other sites More sharing options...
Six_Shooter Posted January 14, 2008 Share Posted January 14, 2008 Most people find that the engine temps change very little if at all using a FMIC. The heat that is passing through and being exchanged by the FMIC is quite a bit less than what the rad or A/C condenser see, hence why it is usually placed farthest forward. I think the hardest part about a SMIC, would be getting air flow through it. Usually these are placed inside the fender and will need some sort of duct work to pass air through the core. I would also be worried about rocks being thrown from the tire(s) into the core and requires some sort of protection, usually a screen of some sort. This will cause a lower amount of air passing through the core due to simple restriction of air flow. I thought about trying to get SMICs to work on my Jimmy, being on the outside of the frame rails, but decided that it would be easier to combine my two cores and place them between the frame, below the rad support I believe that the air flow would also be better. My previous IC was mounted in front of the rad. I know it's not a Z, but just an example. Quote Link to comment Share on other sites More sharing options...
czecho Posted January 15, 2008 Author Share Posted January 15, 2008 The bumper im getting has air ducts in it for the SMIC, its the 99' JDM front bumper and there is plastic guarding the SMIC on both sides so nothing with hit it but the front of the SMIC's would need a grill to protect thats no big deal The front bumper i getting: http://www.amzperformance.com/product_info.php?cPath=11&products_id=116 The SMIC's i want to get: http://www.z1motorsports.com/product_info.php?cPath=6_22&products_id=71 Quote Link to comment Share on other sites More sharing options...
Evan Purple240zt Posted January 15, 2008 Share Posted January 15, 2008 It appears that those intercooler(s) are meant for a TT setup. IE, you would not want flow out of one i/c and all the way across to another i/c. Seems simpler and cheaper to run a single FMIC, which is what I would do. Evan BTW, a thicker core will not make up for frontal surface area. The back half of the core is not as efficient as the front. Granted, I am making little sense but its covered in "maximum boost". Quote Link to comment Share on other sites More sharing options...
