Driveshaft safety loop
blueovalz
My soon to be driveshaft safety loop is still "pink" but it will have hair growing soon. It will have about 1/4" clearance all the way around the driveshaft (entire drive train is solidly mounted). So if I put this midway between the joints, I should have no more than 1/2" of wobble at either end of the failed joint. It's a 3" axle housing clamp in case you're wondering. I'm going to modify it a bit more by using smaller bolts (perhaps some good grade 3/8") being four 1/2" bolts are a little excessive (and weighty) for what is needed here.
