bryan01 Posted January 17, 2008 Share Posted January 17, 2008 can i just put some resistors inline to cut down the current before it hits the injectors (and goes back to the ecu)? from what i've been reading high impedance injectors are 12ohms, and my low's are 3, so if i got a 9ohm resistor before each one, the computer wouldnt tell a difference, but would the injectors still operate properly? the low imped injectors are supposed to have a faster response, would you lose that? would they still work? i saw a few products online called injector drivers that advertised to run low's as high's, and they were pretty expensive if all they are are resistors inline between the ecu/inj. Quote Link to comment Share on other sites More sharing options...
bryan01 Posted January 17, 2008 Author Share Posted January 17, 2008 http://forums.hybridz.org/attachment.php?attachmentid=3890&d=1192064421 so ... yes? Quote Link to comment Share on other sites More sharing options...
bryan01 Posted January 17, 2008 Author Share Posted January 17, 2008 http://forums.hybridz.org/showthread.php?t=79407&highlight=low+high+impedance or no? Quote Link to comment Share on other sites More sharing options...
bryan01 Posted January 17, 2008 Author Share Posted January 17, 2008 http://www.megamanual.com/v22manual/minj.htm if you go down a lil more than 1/2 way it talks about using resistors and has a calculator for how much resistance you will need based on your stock setup and your current inj's ... it's designed for use w/ the megasquirt but should apply to any low imped on a high imped circuit ... i love answering my own questions ... i feel so proud ... now we'll see if it works Quote Link to comment Share on other sites More sharing options...
