How to install temp sender?
Dan, since I don't have my JTR manual in front of my, I'll take a few liberties at answering this question. Since no one else has taken a shot, here it goes:
First, the 3/8" npt hole in your engine is obviously what you have to deal with. The idea, as I remember it, is to use the Datsun temp sender, which is smaller then the old 1/2" hole in the block. What size is the Datsun unit? If its smaller than the 3/8" hole in your block, your probably in luck and only have to get a bushing machined to fit. Otherwise, if it is too big for the 3/8" hole, you have to:
1) have a special adapter made to fit the block and the Datsun unit--even if it sticks out some from the block--I somehow remember someone doing this and running a brass elbow off the V8 and having a fitting for the temp sensor...seemed to work well from what I remember. The big issue is whether or not the sensor will work not being "inside" the block. Well, from what I remember, it did not make a marked bit of difference. This idea may have come from one of the Ford guys, but again, I can't remember.
2) find a smaller Nissan temp unit that would better fit the application.
David
Don't realy want to change my gages. The problem is that the Datsun sender is just slightly smaller than 3/8npt. It will screw in very loosely. Any bushing would look like a Heli-coil. I thought about some type of adapter, but also had concerns that it would not be "in" the block.
The thermostat housing I'm using has a 1/2"npt hole in the top of it. I put a plug in it. Can I use that?
