Dry Sump 2JZ Pan w/ mechanical fuel pump
JustinOlson
I'm looking at going this route on my 2JZ swap. I want to do a mechanical fuel pump so that I'm able to flow the volume I'm looking for on Ethanol. Also, figured it would be a nice time to do a dry sump setup. Most of these parts except the pump bracket are off the shelf parts:
Errol at TPS has some good pictures of this setup on his Black Drag Car... Peterson SBC dry sump pump and aeromotive hex drive fuel pump :)
http://www.esnips.com/web/errolsBusinessFiles?docsPage=2#files
Also found that Moroso does a dry sump oil pan for the 2JZ:
http://store.summitracing.com/partdetail.asp?part=mor-28001
http://www.moroso.com/photo_gallery.asp
Regards,
Justin
