Mauisnow13 Posted February 5, 2008 Share Posted February 5, 2008 I have a 1970 240Z. Where exactly on the car are all of the ground wires located. I have been told I most likely need to clean them all out, but I only know where one is, which is the one inside the passenger fender in the engine bay. Any help would be appreciated. Quote Link to comment Share on other sites More sharing options...
bjhines Posted February 13, 2008 Share Posted February 13, 2008 Hmm... I don't have a 1970 to look at... If it is like the 1972-73 models then there are several front ground points. 1. one on the lower radiator support 2. at least one on the passenger side frame rail 3. I seem to recall one on the driver's side as well, near the coil. 4. There is also a firewall ground point and at least one behind the fuse panel. There are also a lot of ground splices in the harness. They get cruddy in the front clip area and will cause headlight issues. The corner maker light housings are notorious for grounding to the body through the attachment screws. Check these and make sure they are insulated from ground. Quote Link to comment Share on other sites More sharing options...
