z31 clutch issue
Guest TeamNissan
Guest TeamNissan
1987 z31 n/a only 60k miles. No clutch petal pressure but no leak in the system and fluid is topped off. I don't think its air because there is ZERO pressure. Clutch petal assembly is fine.
So I'm thinking master or slave cylinder is shot. What do you guys think?
Thanks in advance.
the clutch isn't quite like the brakes, when you get air int he system the pedal has a tendancy to just stick to the floor, if nothing in the system has changed then most likely it's tha master, it is highly recomended to replace the slave at the same time, and while you'rea at it, you can replacce the clutch damper with a brake line from a rear calliper, the damper serves no usefull functiona nd adds one more step to the bleeding process
