JSM Posted February 11, 2008 Share Posted February 11, 2008 I have questions on some wires from a 73 240z. I looked at the wiring diagram from this post and my smashed 240z I have still electrically intact and determined the following (I think), please correct if wrong: http://forums.hybridz.org/showthread.php?t=100402 Coil Wires 1=Resistor (wire appears black) 2=Green / White – Other side of resistor 3=Black - Neg Side of Coil 4=Black / white – Positive side of coil Dist/Therm wires 5=Black - ?? I think this was a ground on the distributor? 6=Yellow - Thermostat 7=Green - ???? No ideas either 8= Back / Yellow - ?? This may actually black and white but picking up color from the yellow. Where does this go? Points on the distributor? My New car has a MSD coil and MSD 6AL wired through a newer 280zx electronic distributor. All the wires above were hanging off the new car. Tach is not working nor the thermostat. The smashed 240z has a newer 280zx electronic distributor with a stock coil and all the wires are hooked up except for 5, 7 & 8. For the new car, I was thinking to hook up #6 to the therm and #4 to positive side of coil to get my tach working. 4 is the tach wire correct? That gets +12 from the coil correct, not giving +12 to the coil? And #3 is not needed for the tach to work correct? I don’t have to go through the 6AL to get the tach to work, but I think that is an option it has? Can someone tell me what wires #5, 7, and #8 are for? Just for knowledge at least? Quote Link to comment Share on other sites More sharing options...
JSM Posted February 11, 2008 Author Share Posted February 11, 2008 Oh man, I searched some more and I am more confussed then ever. Quote Link to comment Share on other sites More sharing options...
Six_Shooter Posted February 11, 2008 Share Posted February 11, 2008 I'll come back later and study this some more, but wanted to ask and mention this: Are you using or still have the stock '73 tach in the car? The '73 tach, is a voltage triggered tach, where the positive side of the coil coil is fed through the tach. When changing to a different ignition system, most swappers seem to swap to the later points triggered tach. I know the 280Z uses a points trigger tach (I'm getting one from a '78). I don't recall what year this changed. I have seen some install instructions on using the original tach with an MSD ignition system. This was on zhome.com. http://www.zhome.com/ZCMnL/tech/ThomasMSD.htm'>http://www.zhome.com/ZCMnL/tech/ThomasMSD.htm There are a few other ignition articles as well, under the "How-tos" menu. http://www.zhome.com Quote Link to comment Share on other sites More sharing options...
JSM Posted February 11, 2008 Author Share Posted February 11, 2008 Thanks. Yes it is the original 73 tach. Quote Link to comment Share on other sites More sharing options...
