Rebuilding a T5 - Any Suggestions???
Guest mattrp
Guest mattrp
Well, while the motor is getting redone, I've decided to redo the tranny as well. Currently it works fine, but its got a few miles, and Im pretty sure the rear bearing is not in great shape, and it has no speedometer sending gear. So
Got any suggestions for a brand of kit?
Any tricks to doing this tranny?
Any special tools?
Suggestions?
Thanks
Matt
72 500Z
Matt, try www.gearzone.net/T5.htm
if you can find your way back to the front page there are phone #s, email addresses. This guy does a lot of T5 building. Designed the counter shaft stabilizer plate. Supplies parts, too. Check your case carefully. Most of the trans shops I've talked to say the bearing supports get so wallowed out a new case is needed. Usually go with a remanufact. If the case is worn you can find new WCT5s in the neighborhood of $1000-1200
JS
