pparaska Posted August 11, 2000 Share Posted August 11, 2000 I'm not sure if anyone here has seen this but I just happened upon a pretty good write up of a F body T5 to T56 swap. Check out: http://www.drivetrain.com/gmt56inst.html They say that BW made that tranny adapter plate. Sam, do you have any good info on the tranny to bellhousing bolt pattern dimensions from that manual and the location of the input shaft center in relation to that bolt pattern? I'm thinking of making up an adapter plate of my own for a straight up blowproof bellhousing. It doesn't look very complicated. Someday, I'll probably be bitching about the Tremec's shifting quality and will have to retro fit a T56. The only other big issue is the rear mount will have to be moved back a few inches ------------------ Pete Paraska - 73 540Z - Marathon Z Project - pparaska@home.com">pparaska@home.com - Quote Link to comment Share on other sites More sharing options...
