Beating a dead horse, northstar style - and hello!
Guest Demon Z
Guest Demon Z
hey guys, great site. I've read alot to keep inspired. You guys really do some nice builds.
I've had my 240z since '96 or so, back then I collected a lot of parts to convert it to a chevy supercharged 383. I still have all the parts but the conversion isn't quite as interesting as it was back then. I'm very interested in the northstar conversion and have read all the posts on this site (and others) about it. Again, thanks for all the great content.
I want to use this post/thread to collect all the info I've found and place them all in one spot for myself and anyone else who wants to go down this path. Also, please feel free to add, critique, or bash.
The northstar conversion is attractive to me because of the light weight v8, double overhead cams, the rareness of the conversion and the cheapness of used northstar engines (they're going for around $500 on ebay)
major components needed for the conversion:
The rest of the components should be the same as with any other conversion.
Odds and ends:
  • intake needs to be turned 180 degrees
  • water pump needs to be relocated
  • engine wieght: 403 bare, no accessories
  • engine dimensions: 28"W, 26"H, 31"L
  • 275/300 hp 400 ft/lbs
  • '7730 prom can be (and may need to be) further modded with cheap equipment and free software http://forum.tunerpro.net/
  • engine doesn't seem to be rebuildable
  • chrfab offers cams to make 400 hp
Links of intrest:
http://members.tripod.com/~grannys/enginescadillac.html
http://www.fiero.nl/forum/Forum2/HTML/070626.html
http://www.moparchat.com/forums/showthread.php?s=&threadid=71020&highlight=supra
http://tunerpro.markmansur.com/
http://www.chrfab.com/
Thanks for letting me ramble :D
Guest Demon Z
one of my links is hosted by trypod. It may or may not be around down the road. I'm going to paste the info here just in case.
CADILLAC NORTHSTAR
speedwaynorthstarflyer25.gif Design Configuration...
60 degree DOHC 32 valve all aluminum V-8
Displacement...
4.6L (280cid)
Fastener Type...
Metric
Bellhousing Bolt Pattern...
60 Degree GM (special starter location, top center under plenum)
same as OLDS Aurora
Oil Sump Locations...
Front sump cast aluminum oil pan
Distributor / Oil Pump Configuration...
No distributor - coil packs
Right side oil filter (about center at crankshaft level)
Weight - Ready to run...
appx 413lbs
Engine Weight Variables...
Bare - about 400lbs
w/ all accessories - about 470lbs
Production Makes & Models installed in...
'93-up Cadillac FWD models
Model & power info
from Betts Cadillac
Production Induction Systems & Power Ratings...
All EFI - 275-300hp / 400ft lbs
Production Accessory Configuration Notes...
Serpentine drive accessories
Production Transmission Options...
Transverse mount 4spd OD Automatic only
Notes Of Interest To Engine Swappers...
Special bellhousing configuration required by the top/center
starter location from the factory
Can be converted to RWD by using a 700R4 transmission from a
60 degree V-6 powered S-10 or Camaro and welding in a special
pocket for the starter.
Throttle body is in the rear - the plenum can be rotated 180 degrees
to provide the traditional V8 throttle body "in-front" location.
General dimensions - 28"W, 26"H, 31"L
Also now available in a 3.5L V-6 configuration, the "Shortstar"
in Oldsmobile Intrique
Northstar Engine Swaps On The Web...
Custom Northstar parts & info
from Cadillac Hot Rod Fabricators
'49 series 62 Caddy w/ Northstar V-8 (1)
'49 series 62 caddy w/ Northstar V-8 (2)
Northstar Engine Swap Kits & Adapters...
Northstar V-8 / DeLorean Swap Kits
by American Custom Engineering
Northstar V-8 / Fiero Swap Kits
by Design 1 Systems
Northstar Parts & Info Sources...
GM Powertrian Northstar page
New Engines - Speedway Motors (402) 474-4411 ext. 3048
Factory new Northstar engines for an unbelievable $2500.
MecTech - source for custom wiring harnesses
Jim McFarland / Owner (760) 432-0555
Custom bellhousings/flywheels for RWD
and manual transmission conversion
Allen Johnson (949) 498-7000 ext. 5
