82 e-> 82 ET ignition probs
problem: no start
A quick question, when I did the 82 l18e -> 82 L28et swap I swapped in the 82 ET wiring harness and ecu as well as an 82 ET dizzy w CAS, coil, ignitor.
Now I have a couple questions with the ign wiring.
I pulled the plastic cover BEHIND the fusible links where the green fuel pump relay is and I spliced 4 wires from the plug in there into the matching color wires (green-to-green, black/white-to-black/white/ yellow to yellow, yellow to yellow). Are these supposed to be like that? I just took the 4 wires in the back of the unhooked plug and spliced them into the 4 same colored wires in the chassis harness.
Also, Im having a problem with the semantics of "transistor." What exactly does the transistor look like? Is this the ignitor? Is it necessary to have in my swap?
I have the noise condensor hooked up and know what that is.
I also ran one wire from the clip next to the ecu to the thick yellow wire on back side of the ignition switch (12v switched)
as well as ran a wire from the same clip to the ignitor... I assume this wire signals the coil to spark?
ANY help would be appreciated, I already worked for months to get it running once so now I want to shoot this thing
