Guest Anonymous Posted December 26, 2000 Share Posted December 26, 2000 I am looking at a 79 280zx with a 5 speed. The car is quiet until I get it in gear. When in gear it makes a constant loud whining noise. Is the trans possibly going bad or just the clutch. The car shifts into all gears and is pretty smooth just noisy. Quote Link to comment Share on other sites More sharing options...
BLKMGK Posted December 26, 2000 Share Posted December 26, 2000 How's the fluid level in the trans? Is it the right fluid? Quote Link to comment Share on other sites More sharing options...
Guest Anonymous Posted December 26, 2000 Share Posted December 26, 2000 I was going to say, throw out bearing, but if it doesn't do it in neutral as well, it may be the front bearing in the transmission going bad, they'll do that under load. Just a guess mind you. Lone [This message has been edited by lonehdrider (edited December 26, 2000).] Quote Link to comment Share on other sites More sharing options...
MYRON Posted December 27, 2000 Share Posted December 27, 2000 Does the noise change as you push in the clutch when it is in neutral? If the noise does not change it may be a layshaft bearing. Myron Quote Link to comment Share on other sites More sharing options...
