J Taylor Posted December 16, 2000 Share Posted December 16, 2000 My 280 keeps breaking the 280zx na trannies so I want to get at least get a t5 in it. Anyone know how much I need to have a driveshaft shortened to make it work? Anyone have any kind of aftermarket tranny in their Z? T56, tremec, etc, etc, etc. I need something that's going to stand up to some abuse and alot of power. Thanks alot. JT ------------------ 1978 280z with 280zx turbo motor. Big turbo, big intercooler, and alotta boost. 8.4 @ 90 1/8 mile with a bad bad traction problem. 1994 Mustang Cobra with a few mods..... http://turbotaylor.homestead.com/files/index.html Quote Link to comment Share on other sites More sharing options...
Guest MistaFosta Posted December 26, 2000 Share Posted December 26, 2000 Lol. Sounds like too much power.... Good job! Didnt the 280ZXTs have a t5? Still, a t-5 would get eaten alive by that motor. Cant take high horse...There is a company called Transdapt that might be able to make a conversion bellhousing, prices are reasonable from what Ive seen. Good luck Quote Link to comment Share on other sites More sharing options...
BLKMGK Posted December 26, 2000 Share Posted December 26, 2000 A T5 built "right" shoudl be able to take the power of a turbo 6 IMO. Lot's of upgrades have been made to that trans in the years since it was last in a Z. Find yourself one that will bolt up and if you're worried about breaking it give HanlonMotorsports a call. I'm pretty sure their WEB site is http://www.hanlonmotorsports.com Bob is a good guy and races a Mustang. He uses what he sells, he ought to be able to build a T5 more than capable of handling that 6 and many V8s too! Quote Link to comment Share on other sites More sharing options...
J Taylor Posted December 26, 2000 Author Share Posted December 26, 2000 Mista: Yeah, the 280zx turbo tranny will bolt right up but I just have to have a driveshaft shortened to make it work. I am in a way hesitant about doing this b/c even my old 84 turbo tore up it's t5 twice with waaaay less hp than what the 280 is putting out. BLKMGK: If was going to go through the expense and trouble of building a t5 I would much rather go through a little more throw in a tremec or something. Know what I'm saying? JT ------------------ 1978 280z with 280zx turbo motor. Big turbo, big intercooler, and alotta boost. 8.4 @ 90 1/8 mile with a bad bad traction problem. 1994 Mustang Cobra with a few mods..... http://turbotaylor.homestead.com/files/index.html Quote Link to comment Share on other sites More sharing options...
BLKMGK Posted December 26, 2000 Share Posted December 26, 2000 Heh, ever shifted a Tremec? I have - I've got one in my Mustang. I still can't hit third gear reliably after driving the smooth T5 for so many years. The Tremec's tend to shift crappy, and the stock Tremec shifter is complete junk! Now, a T56 - that would be a nicer trans! But the expense would be crazy I'm afraid. Up to you obviously but a modded T5 would be the next best step up from a T5 and might not be as expensive as you think. If you've broken T5s with less HP before than a stock one is probably not going to last this time either. (shrug) Quote Link to comment Share on other sites More sharing options...
randy 77zt Posted December 27, 2000 Share Posted December 27, 2000 has anybody tried a world class t5 on a zxt bellhousing?the mustang racers have good luck with these and you can get new units from summit.you would have to use a dikfferent clutch disc cause spline count is different. Quote Link to comment Share on other sites More sharing options...
Guest Anonymous Posted December 27, 2000 Share Posted December 27, 2000 Hey JT, see if an 87-89 turbo transmission will bolt up to a 280ZX turbo t5 bellhousing. If it fits I'd do that. Expensive and needs a custom driveshaft, but pretty hard to break it! Or you could just quit tearing the **** out of your cars and then you wouldn't break transmissions. That'd be the cheap way to go! ------------------ Morgan http://z31.com/~morgan/s30 http://carfiche.com Quote Link to comment Share on other sites More sharing options...
J Taylor Posted December 27, 2000 Author Share Posted December 27, 2000 BLKMGK: Yeah, my first stang had a tremec 3550 in it and I didn't have any bitches about it other than the stock shifter that was on it. I do like how the t5 in my cobra feels alot better but I could definately get used to the tremec knowing I could shift the hell out of it without breaking it. Morgan: The input shaft would have to be changed though, right? JT ------------------ 1978 280z with 280zx turbo motor. Big turbo, big intercooler, and alotta boost. 8.4 @ 90 1/8 mile with a bad bad traction problem. 1994 Mustang Cobra with a few mods..... http://turbotaylor.homestead.com/files/index.html Quote Link to comment Share on other sites More sharing options...
Guest Anonymous Posted December 27, 2000 Share Posted December 27, 2000 I dunno. I bet all these nissan things have the same clutch spline(just a hunch, but who knows). If splines are wrong you can mix-n-match discs and plates to get it to fit. ACT could do that for you no sweat. The release bearing might take a few tries to get it in the right position though, but that's not a big deal. If the shaft is the same length, then you only need to worry about the pilot bushing. Worst case on that is you get a piece of bronze stock and have a custom bushing made. It's worth at least looking into. This also means that a z31 turbo t5 would fit, as would a z32 transmission(same as 87-89 turbo) and give you lots more choices and cheaper prices. ------------------ Morgan http://z31.com/~morgan/s30 http://carfiche.com Quote Link to comment Share on other sites More sharing options...
J Taylor Posted December 28, 2000 Author Share Posted December 28, 2000 The dude in Auburn that basically built the car originally said I can't use a z31 tranny....input shaft is different. I think what I am going to do one more time is get another na tranny to throw in it to buy myself some time to figure out what to do about getting a tranny that will hold up. The guy I got the last tranny from said he would swap it for another since it only lasted a whole 5 days so it is only costing me labor which is no biggie. Maybe it will last longer than 5 days this time..... JT ------------------ 1978 280z with 280zx turbo motor. Big turbo, big intercooler, and alotta boost. 8.4 @ 90 1/8 mile with a bad bad traction problem. 1994 Mustang Cobra with a few mods..... http://turbotaylor.homestead.com/files/index.html Quote Link to comment Share on other sites More sharing options...
