megaview in tach pod
datman
After removing my dash i have been thinking about options for my Tacho as the old one won't work with MS. I've decide to use a tinted perspex lens and mount the mega view in the back of the tacho pod. The screen just fits inside, will post some pictures of it later tonight.
This is a great idea. Now you need some flat black material as a mounting surface. In that mounting surface you can put your Megaview, several leds and maybe a push button or two. How about:
shift ligths
turn signals
indicator lights - whatever you need to show??
O2 cal button - like that idea
VE-Spark Table switch button??
I will have to keep up with this because I also need a new tach!
HB280ZT
I was thinking more along the lines of smoked plexi between the megaview and the tach pod screen, this will only allow the screen digits to be viewed.....I made a tinted plexi screen to go in place of the radio but then decided this would be a better idea. I will probably use that static tinting stuff you can use on windows .
I think one of those 4 way mirrow joystick switches would be good for the contol switch.
  • 3 weeks later...
