Accelerator Rod Boot Help.
Guest smills55
Guest smills55
I guess I must lack the vocabulary to successfully work the search function because I have been searching for the past couple of hours using works like accelerator, throttle, boot, and fire wall with no luck. Can someone please refer me to a link or thread on how to replace an accelerator rod boot that I purchased from Black Dragon Automotive?
Thanks in advance.
1975 Stroker 3.1
I cant remember exactly, but I think you separate the white plastic ball joint from the rocker linkage, right ahead of where the boot goes, and screw it off the rod so the boot can slip on the rod. If you do this, mark the length of the rod so when you screw the ball joint back on it goes to the same length.
I may be wrong but the service manual may tell you how to do something like this. It's not really all that difficult.
