Welded Rear Caliper Bracket?
I was having a rare thought and I was wondering if any one has Welded on the Rear Caliper Brackets? Not welding the "Bolt on" brackets but cutting a fitted bracket to suit the strut and welding it on?
The only thing I can think of is the possible distortion of the bearing alignment?
All answers positive or negative welcome
You would never get it rego'd - nor, it the name of safety, should you be allowed to!
Look up the design rules; there can be no welded brake components.
See Section 5.2, Modification of Components. Second dot point.
http://www.infrastructure.gov.au/roads/safety/bulletin/pdf/NCOP5_Section_LG_Brakes_3Feb2006.pdf
Remember Mark Webber in qualifying for the AGP - not a weld failure, but brake failure is serious stuff.
