First drive with the LD intake swap
To catch up on my build
http://forums.hybridz.org/showthread.php?t=131932
Today was the day. Finished the throttle cable and went for a drive. First video is with my real camera, then the batteries died, so I have to go back to my phone for crappy quality. As I was uploading from my phone, I realized I had the video on the lowest setting.. BAH!! Theres the problem.
did you ever dyno the old setup? you need to throw this one on to compare!
sometimes i kinda wondered what would happen if you took an LD intake, cut the runners off almost parallel with the head, then cut the rest of it off of the main plenum, then welded the plenum to those runners, placed the injectors on the top...it'd be a cheap alternative to the stock Z-car intake....
hmmmmmm
get some better videos!
