Guest Anonymous Posted February 27, 2001 Share Posted February 27, 2001 OK; heres a weird one. When I accelerate the car squats and the rear end seems to move to the left. When I let off the gas it seems to move to the right. What the? I am thinking motor or transmission mount. Have any of you ever experienced this? I dont even have a clue. This did happen very suddenly. And there are no weird vibrations. Thanks, Peter Quote Link to comment Share on other sites More sharing options...
John Scott Posted February 27, 2001 Share Posted February 27, 2001 Yes, I had this happen in another car. Kind of like 4 wheel steering Rear end mounts had play. Check your bolts bushings etc. Had a similar effect when my tension rod up front came loose. That 'bout put me in the ditch. JS Quote Link to comment Share on other sites More sharing options...
TimZ Posted February 27, 2001 Share Posted February 27, 2001 Not trying to be a smart ass here, but have you checked your rear tire pressures? I had these identical symptoms, and I originally thought the worst. The effect was quite pronounced. Embarrassingly, it turned out that one of my rears had lost pressure due to a slow leak. When I brought everything back to correct pressures, the problem went away. Quote Link to comment Share on other sites More sharing options...
clint78z Posted February 27, 2001 Share Posted February 27, 2001 I think the Z is quite sensitive to this, used to happen when I drove my car in the winter for a few years . It was very pronounced on ice and ruts, 5 psi made a huge difference . Quote Link to comment Share on other sites More sharing options...
