L28 turbo swap question
bianski
Hey Zers
ive been searching and found almost all of what i needed to know but can you Run this.
77 280Z block(dished pistons)
P90 head
turbo exzhuast manifold
280ZXT stock turbo
turbo oil pump
Turbo Dizzy
FMIC
Turbo intake manny
77 N/A ECU
280ZXT AFM
280ZXT injectors
ive searched and ive read people doing the turbo with n/A ecu. but i couldnt figure out how it would work with a setup like this.And would it also work better with the N/A AFM or the turbo AFM well out of these parts how it run the best if at all?
You can't use the turbo distributor with the NA ECU. You need to get yourself a turbo ECU and harness. Or run standalone. Also, the NA dished pitons are not the same as the turbo ones. I do know people that have run them in turbo applications without problems, but other I know have had problems. Run it for as long as it lasts, then find an F54 turbo block and pistons in good shape.
There's a reason your old thread (over here) was put in the tool shed.
All this has been covered waaayyyy too many times.
By the way, the difference in pistons is the ringlands. The NA ones aren't as strong and take a lot less detonation to destroy. Old turbo kits on NA cars used the cold start injector activated by a pressure switch at a certain boost level.
It works but the driveability is crap compared to a more modern EFI system.
Also, I believe the pin outs for the AFM are different between turbo and NA models.
Mario
how about instead of saying you need to search how about you find it and put up a link to help me out. ive been reading over threads for about a year now and there are some things i just cant find. Why is everyone on here think they are so great and talk down to everyone.
This kind of post won't get you too far with this crowd. There are a few on this forum that do talk down to people, and frankly I wish they would stop it. Your post above will only add flames to that fire BTW.
For some of us, having to answer the same questions over and over again, gets really old. I answered the same questions (again) in my first post to this thread. Did I say the 77 280Z didn't have dished pistons? Please read my initial post again....
sorry about that Z-ya. Its just some people get under my skin and i normally voice my opinion so yea sorry man. Thanks for all your help and i know you guys answer a lot of the same questions but the questions are always gonna be asked over and over. And now that im gaining knowledge i will happily answer the same question for different people just because i know that it helps in some way thats what forums are for and i thank you for not talking down on me or being a jerk when so many others just show their embarrassing side to them
