vegasnative Posted April 10, 2008 Share Posted April 10, 2008 I am installing megasquit 1 with pcb v 3.57 with ignition driver. my setup is as follows; f54 88mm forged pistons ld28 crank 60mm tb t3/t04e turbo 350 cc injectors 83 turbo dizzy n42 no egr intake 5 speed r180 3inch downpipe and exsaulst p90 with oversized ss valves thanks in advance jerry Quote Link to comment Share on other sites More sharing options...
proxlamus© Posted April 10, 2008 Share Posted April 10, 2008 http://forums.hybridz.org/showthread.php?t=99689 see if there is a map posted that might match your settings =) Quote Link to comment Share on other sites More sharing options...
vegasnative Posted April 10, 2008 Author Share Posted April 10, 2008 Yea, I have looked at that thead many times just not sure what one would match up with my setup. Any help would be apprecated thanks jerry Quote Link to comment Share on other sites More sharing options...
Slow_Old_Car Posted April 13, 2008 Share Posted April 13, 2008 save yourself waisted time, upgrade the injectors now before you start tuning... Quote Link to comment Share on other sites More sharing options...
vegasnative Posted April 14, 2008 Author Share Posted April 14, 2008 Slow_Old_Car said: save yourself waisted time, upgrade the injectors now before you start tuning... Why do you say that? Any maps? Quote Link to comment Share on other sites More sharing options...
Slow_Old_Car Posted April 14, 2008 Share Posted April 14, 2008 vegasnative said: Why do you say that? Any maps? you have a stroker with a head that is reworked, it should move more CFM up untill the manifold choke point. guys on stock displacement are maxing out 440cc supra injectors with not to terribly much boost, so depending on your power goals you will find the ceiling of those injectors fairly quickly. Quote Link to comment Share on other sites More sharing options...
vegasnative Posted April 15, 2008 Author Share Posted April 15, 2008 Yes I will upgrade injectors along with intake and fuel rail once i get the engine up and running Quote Link to comment Share on other sites More sharing options...
