72 240z brake issues
So I have a 72 240 that I rescued awhile ago from sitting for 15 years. brakes wise ive replaced teh front callipers with yota calipers, rebuild the rear wheel cylinders the right way, replaced the master cylinder, took apart each of the 3 valves and cleaned them throughly. What I have going on is when the car isnt running there is good pedal pressure but when the car is running there is none. Ive bled the brakes over and over again and checked for leaks. also the pedal makes a nasty clunk when you push it in. Any ideas? I more concerned about the nasty clunk I can figure out the pressure issue.
