LC-1 Gauge Settings
Lukaniuk
I have my LC1 WB O2 sensor wired up and making sense with megasquirt but the values I get on the gauge seem to be messed up. I have the gauge connected to analog output 1 (the yellow wire). What values should I have in LM programmer for voltage and lambda (or AFR) for the gauge to be working properly?
The values are listed in the LC-1 manual. 0v is 7.35 AFR and 5 volts is 22.39 AFR.
The yellow wire's default setting is a narrow band setup and the brown wire is setup by default for wide band.
Thanks, I looked in the manual but couldn't find it.
