Lukaniuk Posted April 17, 2008 Share Posted April 17, 2008 I have my LC1 WB O2 sensor wired up and making sense with megasquirt but the values I get on the gauge seem to be messed up. I have the gauge connected to analog output 1 (the yellow wire). What values should I have in LM programmer for voltage and lambda (or AFR) for the gauge to be working properly? Quote Link to comment Share on other sites More sharing options...
ktm Posted April 17, 2008 Share Posted April 17, 2008 The values are listed in the LC-1 manual. 0v is 7.35 AFR and 5 volts is 22.39 AFR. The yellow wire's default setting is a narrow band setup and the brown wire is setup by default for wide band. Quote Link to comment Share on other sites More sharing options...
Lukaniuk Posted April 17, 2008 Author Share Posted April 17, 2008 The values are listed in the LC-1 manual. 0v is 7.35 AFR and 5 volts is 22.39 AFR. The yellow wire's default setting is a narrow band setup and the brown wire is setup by default for wide band. Thanks, I looked in the manual but couldn't find it. Quote Link to comment Share on other sites More sharing options...
