Quick question.. probably asked 100 times already but..
QWKDTSN
couldn't find it in the search. When moving the differential back (using the curved rear arm bracket, 72-73, that hangs from the link braces instead of the straight one, 70-71), wouldn't I need a longer driveshaft? It only makes sense to me that diff farther back = longer driveshaft needed. JTR book makes no mention of this. It's not like the driveshaft can stretch somehow, can it?
The R180 and R200 have the same nominal dimensions - that is, the mounting points, input shaft location and output shaft locations are the same as the R200.
So if your car already had the mustache bar with the little curve in it, mounted with the bushing rings forward (and behind the rear vertical uprights), then you're driveshaft is the correct length.
240Z.jeromio.com
