Guest datsun83zxt Posted April 28, 2008 Share Posted April 28, 2008 I have a quick question, I have this 1987 300zx im thinkn none turbo but Im not sure yet I havent had the time to stop, but will the injectors and ecu from that car work in my 1983zxt 5-speed mine use to start but when it did it spit and and pop under the hood like in the intake but now it wont even start. im not sure if that car (300zx) is a manual or not either but will someone plz answer my question I would really appreciate it. Quote Link to comment Share on other sites More sharing options...
DuoWing Posted April 28, 2008 Share Posted April 28, 2008 You can use the injectors and ECU, but to do that it will require extra wiring, swapping the rotor plate from the 300ZX distributor to your 280ZXT distributor, as well as wiring up the MAF from the 300ZX in place of the AFM. To use the injectors you would need to wire up dropping resistors into your ECUs harness. So yes it can be done, but no it won't just swap over without some work. Quote Link to comment Share on other sites More sharing options...
