350 combo
Guest gcsd22
Guest gcsd22
hey guys, I'm planning on pulling the 350 I have out of my camaro and putting it in a 280z.
Current specs:
Bored .060 over
#441 heads, lets say stock, they may have a little porting done to them.
222/222 .443/.443 lift cam with 1.52 rockers.
Edelbrock Performer intake
600 cfm holley, vacuum secondary.
Drove a 1980 Camaro (~3800lbs to 14.3@98)
When I put it in the Z I want to go to aluminum heads for the weight and I would like more power.
Any suggestions on heads? Maybe change out the carb and intake too?
If I could find my way into the 12's that would be nice..
Thanks,
Pete
ID suggest building a combo to maximixe the 350s basic ideal power range of about 3500rpm-6700rpm,something similar to this,
this intake and 200cc heads and solid flat tappet cam, & 750 cfm carb matched to a manual trans or 3200 stall converter and 1 3.73:1 -4.11:1 rear gear ratio
http://www.jegs.com/i/Brodix/158/1021001/10002/-1/760699%7C10187
http://www.jegs.com/i/Holley/510/300-25/10002/-1
http://www.jegs.com/i/Crane/270/113841/10002/-1/746648%7C10707
http://www.jegs.com/i/Barry%20Grant/132/5402010BC/10002/-1
the differance from what you currently have will be noticable,
BTW WHERE IN FLORIDA?, IM in PALM BCH
Guest gcsd22
Hey thanks for the advice grumpy. Yeah the setup is alright now, forgot to mention the c.r is about 10:1 and the cam although I don't remember the LSA is a stock chevy 327 cam.
I work in Palm Bay but i'm originally from Bradenton which is probably where the car will be pieced together. Been to West Palm couple times for diving/other stuff, good to know a guru isn't too far away.
