ottoauto Posted May 4, 2008 Share Posted May 4, 2008 I got a rebuilt distributor through work and istalled it with a new crane ignition unit. I couldn't get it to run with the crane ignition unit so i took those out just so i could see that it would run with the distributor. the best i got was a few light fires. i played with the timing a little and it didn't fire anymore. i was using the 240z dist. plate because the dist didn't come with one and i did have to modify and kind cut out a place for the bolt. are the plates that different? any ideas? Original setup; Stock dist (73 240z), stock wiring and all, ran perfect. Drilled dist. plate ran really quite well. Aftermarket; 1980 elect. dist. crane coil (aftermarket ooooo ideas, maybe only setup for the crane ignition setup), simply elect ignition wiring. trying to make my hi6 crane ignition work. ideas Quote Link to comment Share on other sites More sharing options...
ottoauto Posted May 4, 2008 Author Share Posted May 4, 2008 I got it running. runs good. feels a little held back but im going to check the gauge of my wire shortly. ill let everyone know how my crane ignition works out. Quote Link to comment Share on other sites More sharing options...
