abe280z Posted May 18, 2008 Share Posted May 18, 2008 Anyone,i did the turbo swap that bumble zee posted,1983 280zt into 1976 280z.Everythings seems to be working correct,but no fire to sparkpluges,I have 12v to the coil when the ignition is on but, when trying to start the engine i have no fire to the pluges. Is it because i didnt use the 83 turbo ignition switch or what? Quote Link to comment Share on other sites More sharing options...
PanzerAce Posted May 18, 2008 Share Posted May 18, 2008 Did you check to see if you were getting spark before putting the plugs in? Are you sure that you are getting fuel? Double check that you have the plugs wired correctly to the dist as well. Quote Link to comment Share on other sites More sharing options...
Robrob Posted May 21, 2008 Share Posted May 21, 2008 I was in the same spot you were last week. It turned out to be a bad coil, but my injectors are still not firing. Good luck dude. Quote Link to comment Share on other sites More sharing options...
