twoeightyzx Posted May 21, 2008 Share Posted May 21, 2008 A while back I posted that I had an issue with my passanger high beam being out and my low beam was dim. The general outcome was a weak ground, however, I reconnected the previous owners additional ground and still no change. I recently hooked up a test light into the sockets and found there was no power running though the high beam wire. Any suggestions on the fix. I'm trying to avoid cutting the wire loom and but if nothing else I've thought about cutting and splicing into the driver headlight wiring. Quote Link to comment Share on other sites More sharing options...
twoeightyzx Posted May 21, 2008 Author Share Posted May 21, 2008 Just did more investigating and found that unplugging the connection to the passanger headlight leaves the driver side light on. Unplugging the driver side connection turns them both off. I forgot to mention earlier that when I pull the lever for the high beams the driver side goes to high but the blue indicator doesn't come on. Quote Link to comment Share on other sites More sharing options...
