i need some help i am a newb
Guest someguy0719
Guest someguy0719
i am trying to put a blow off valve on my 1982 280zx turbo and dont know how to do it or all of wat i need so if some one could help me i would appriciate because after i get that mounted i am going to mount a manual boost control and i was wondering if 10 psi was safe on the stock motor or do i need to change some stuff out and if so wat all do i need to do
Do some research on the BOV. There's tons of literature on them - and use the search function at the top of the page here. They're pretty easy to understand and install if you know how they work.
You might be ok at 10lbs, but again, use the search function and see what others have had success with. I would consider using an intercooler.
