back-up tighten
well ive been hunting down my brake problem
"very soft "but braking" then rock hard and if i push on it it locks"
problem.
so i started by getting the back brake's tightened up a bit
the left was ok needed a little tightening
the right was very loose
and when i took the drum off "stock new brakes" it was very hard to get off
and when i did get it off the rear pad was yellowish.... not sure why the front looked normal
anyways i tightend it up a bit a little 2 tight but i couldnt back it off since i didnt have the right tool
ok so when i drive forward its easier but when i go in reverse it like having the brakes on i noticed this before when i first put in the brakes then it kinda went away did i over heat the rear pad?? did i install something wrong?
i put new wheel cylinder, lines, pads when i did the brakes
thanks Matt
