Guest jens Posted August 31, 2001 Share Posted August 31, 2001 Would it be hard to make it work with a carb 351W. Quote Link to comment Share on other sites More sharing options...
Dp351zcar Posted September 1, 2001 Share Posted September 1, 2001 I was planning to run one and I have the aod but thats about as far as I have gotten so far. What I was wondering was if the aod would fit in the tunnel with the motor set in so that the cylinder heads allmost touch the firewall. As far as I know the aod will work with a carb. The problem is getting the tv cable hooked up correctly. Don Quote Link to comment Share on other sites More sharing options...
Guest jens Posted September 3, 2001 Share Posted September 3, 2001 How much torque/hp can the aod or the improved aode handle without modifications. A 400 hp 351w has got much more torque than a built 302 so im curius as i dont want to pay 900-1600$ for a improved exchange trans. A aode and the 400$ baumannengineering programmable trans controller seems to be the best choice to avoid the aod tv cable. Quote Link to comment Share on other sites More sharing options...
