A w28 block
F22Barrier
has anyone else messed with this type of block? I could not find a l28 but i found a w28 in an 82 maxima. i had to drill out the oil galley from the oil pump to the undrilled rear pick up and nad to tap a new hole for the rear pick up. the block is the exact same but drilled diffrently =[ so it requires to also move the dip stick towards the rear of the engine and seal the old oil pick up mounts and old dip stick hole. its really a pain in the ass. i recomed just to rebuild an od l28 but my block had a 4" crack down the side.
