Coilover parts help
Have just switched from Carrera struts to Bilstein. The Bilsteins have a larger threaded portion (where the top nut goes on). I need the shim that goes over the shaft on the bottom side of the monoball. I have no idea what this part is called. It's a spacer between the monoball and the top spring perch. They are both 30mm in length.
The one on the left has too small an inside diameter. The one on the right is the correct one that I need.
The one on the left measures 11.90mm ID and the proper one that I need on the right is 14.2mm ID.
I went to Port City Racing and they have something similar but still not a large enough ID.
Any ideas where I might scare up 3 more of these?
Thanks!
