Different Wiring for HEI on 240Z
1972 240Z: so i tried to setup the HEI with the ZX dizzy and Blaster coil using the recommended wiring per: http://zhome.com/ZCMnL/tech/gmhei.html
...didnt work. so i just put the long black/white that went to the ballast resistor to the coil + and left the short black/white that was supposed to go coil+ disconnected as well as the green/white and it runs...
just wondering if it is safe to run it this way? this is a lot easier and simple than the recommended wiring. im having trouble with the advance tho, timing light says it is running best at around 15*? does that sound right?
oh yea and my tach doesnt work now...
