Help with Harness on RB25DET
Cammo
Hi I need som help with a standard RB25DET.
At the ECU there is a white connector called 8-82 or W-1 in the Geez engine diagram. Well... on my engine harness I have 2 of those. The W-1 and a smaller one.
Anyone that knows what it is and maybe have a diagram with this connector?
Ok many thanx... I´ll just leve the small one alone and focus on the big one. The wireing is pretty done but I have a small problem.
I have to remove the ECCS relay and place 2 wires instead to get power to CAS and ignitions. Both ECCS and IGN Relay are new, is this usual or is my ECU wierd? I know both this relays are opend by earth signal from the ECU.
