HELP with Quarter Window weatherstrip
I bought the quarter window outer weatherstrip from MSA and I don't know which side is OUT. On the weatherstrip, one side is lower than the other side, which side is to be used on the outside? The lower or higher side?? Please help, my stock ones were so nasty that I couldn't tell.
It's a coupe, 1977 280z with the correct window trim pieces and glass.
Unfortunately, the car sleeps at another house and its too late to go back. The weather strip is shaped like a "U", the bottom of the U is to glue to the window frame and then there are the 2 parts that stick up. One side is about 1/2 the height of the other side.
I just got off the phone with MSA and they said that the high side goes to the outside of the car and it should be very tough to push into the location. I think I am going to need lots of soap suds for this one...
You can use Murphy's oilsoap to help you push that in, it'll slide well and won't hurt the rubber.
