I don't have a Neutral Position Switch?
uefa5
So my 75 doesnt start b/c when you crank it there is no power to the fuel pump, the pump works just fine when it has power but its not getting any, ive traced all the wires to it and they are all fine. I was reading up about the interlock system since my interior is currently gutted when i realized that i dont have a neutral position switch.... could this be causing the engine not to start as a "safety feature".....if so where can i get this switch, or is there any way to fool the car into thinking its in neutral
thanks
Some Z's do have a neutral switch on the side of the tranny but they have nothing to do with starting the car. In the 240's it would cause the fasten seatbelt light (and buzzer) to turn on if you put it in any gear unless the driver's belt was clicked in.
Some later Nissan's had them too, but it was a signal to the ecu to richen it up on deceleration.
