SR20 power ouput, years, dates...lies
Devilcat
Every one looks for this crap to arm chair build. If you got more dump it here.
1991-1993 S13 Silvia & 180SX
202 hp @ 5300 RPM
203 lbft @4000 RPM
Garrett T25: 0.64 A/R Exhaust, 0.80 A/R Compressor.
High port head, 370 cc/min injectors, red valve cover.
1994-1998 Sl3 180SX
202 hp @ 5300 RPM
203 lb/ft @ 4000 RPM
High port head, 370 cc/min injectors, black Valve Cover, Flat on top.
1996-1998 S14 Silvia
217 hp @5000 rpm
203 lbft @ 4800 rpm
Garrett T25: 0.64 A/R Exhaust, 0.80 A/R T04B Compressor, ball Bearing, Low port head, 370 cc/min injectors, VTC Variable intake Cam, Black Valve Cover with a hump that peaks at Cylinder No .3
1999-2001 Sl5 Silvia
247 hp @ 5400 rpm
202 lbft @ 4800 rpm
Garrett T28, ball Bearing, 0.64 A/R Exhaust time, 0.60 A/R T04B
Low port head, VTC Variable Intake Cam, 444 cc/min ejectors, better materials in turbo and better waste gate flow design. Black Valve Cover with a hump that peaks at cylinder No .3.
ADD: The S15 not only has the most power and best factory turbo, injectors are actually 480cc, it also has a nice 6 speed tranny that keeps you right into the meat of your powerband in between shifts. Rumors say that the 6 speed is weaker but thats bs because Iv never seen one fail before.
Even if the internals are weaker I remember a thread taking the gut out of a RB25 trans to fix that. Thanks for the add on the 480cc's, perhaps there is a slit veriation on the S15 not as yet known. The s14 and S15 share the same turbo to that's a nice thing since, as you said Z2000 its a good unit. I noticed a typo for the S15 turbo and it should be: Garrett T25: 0.64 A/R Exhaust, 0.80 A/R T04B Compressor.
I think you'll find the s15 had different turbos depending on the market it was released in. I dont know whats what but I know JDM s15's have a different turbo to AusDM ones
I've heard of people breaking silvia 5 speed gearbox's, and i've seen a couple of "high hp" s15's converted back to 5 speeds so there must be a reason for this?
