MikeZcar Posted July 31, 2008 Share Posted July 31, 2008 Ok it's not a Z but may have part of one in it soon. 1st off I'd rather be working on 1 of the Z cars but need this ready to go by fall. 1984 Nissan "Mirage" camper. Fiberglass shell on truck platform. In 5th there is a steady thunk, thunk ,thunk or knock, knock, knock if you prefer from the transmission it' in 5 th gear under a load only. Not real loud but very steady till you let off the gas. Carrier bearing rubber was bad so changed it, noise still there. Pilot bearing? Input bearing? Output bearing? Something loose? Is this what happens to Z car trannys, never experienced it but have read about "nut" coming loose. What might it be? Is it worth fooling with? ie simple fix Will 82 ZX tranny bolt in? (gearing the same) Mike in Arkansas, working on '72 Turbo Tom project Quote Link to comment Share on other sites More sharing options...
cockerstar Posted August 4, 2008 Share Posted August 4, 2008 Well, which engine is in it? Quote Link to comment Share on other sites More sharing options...
