Ok to use L24 manifold gasket on an N42?
Babalouie
Is it ok to use a L24 gasket on an N42 head?
I ask this because I notice that the N42 head has these notches for the injectors...
...that look like they might protrude into that triangular hole in the L24 gasket...
So would it seal properly?
I am running an N42 with SU's in my 72. I had it leak at that position about 10 years ago. My solution was to replace the gasket, and the problem was solved. I do not know what gasket was leaking (240 or 280), nor can I remember what type of gasket I put in it.
What I do recall is that it had more to do with the installation than it did with what type of gasket. I had a helper ensure the manifold was in the up most position to maximize sealing surface area while I snugged it down.
Apparently according to the knowledge I gleaned from the guys who reco'ed my head ( they do most of the work for the QLD z club ) the injector holes can muck up the flow a little.They counseled welding them up but I decided against it as EFI and turbo is in the future for my car.
N42 Stock setup +triple dellortos on a redline manifold. I have the same style of gasket as you have ( though newer by the looks of it :-D )
PS. Been watching your car on jdmstyletuning. Lovely machine.
Cheers :D
That gasket's the oldie that came off the engine and JDM manifold...I will of course use a new one when I put the Redline manifold on :D
