SidWell Posted August 10, 2008 Share Posted August 10, 2008 I finally found the config setting that will allow viewing the O2 sensor reading while cranking. In Fuel Set-up, Other Fuel Settings, there is a setting called Max Cranking speed. If your setting is greater than your crank speed, the O2 sensor will not be active. If the Max Cranking speed is less than the actual cranking speed you will see the O2 sensor responding. I spent way too much time trying to figure this out. Quote Link to comment Share on other sites More sharing options...
