darts new SHP block
http://gallery.barrymorrison.com/albums/userpics/10001/SHP_Brochure-1v2a.pdf
http://www.jegs.com/p/Dart/1029740/10002/-1/10719
AT $1456 there not CHEAP but they a certainly a BARGIN compared to putting $1000 in machine work into a 35 plus year old chevy block thats noware near as stong and very likely to be rusted internally and one that might have cracks
and at $1000 less than thier full race block its a deal for a street/strip engine combo
http://www.jegs.com/p/Dart/1064093/10002/-1/10719
whats the differance?
its got a bit less machine work, its not quite as thick and its got less nickle in the casting, and theres less options
IF theres any way your going to invest in a decent aftermarket block as a base for a SBC you sure want a relieable/durrable rotaing assembly, ID strongly advise a 5140 04 4340 FORGED CRANK and 7/16" ARP rod bolt rods and a bit of thought as to the compression ratio, forged pistons and a decent valve train to avoid damage to the block
with a 4340 FORGED crank theres not much in the way of significant mechanical strength lost going to the more comon 350 main bearing size journals and you reduce the bearing surface rotational speed just a bit so rotational frictions reduced slightly and most SBC cranks are designed for that bearing dia.
CHEVY SMALLBLOCK V-8 Crankshaft Casting Numbers
SBC TWO PIECE REAR MAIN OIL SEALS
1130.......327.......forged..medium journal...3.25" stroke
1178.......302.......forged..medium journal...3.00" stroke
1181.......305,350...cast....medium journal...3.48" stroke
1182.......350.......forged..medium journal...3.48" stroke
2680.......327.......forged..small journal....3.25" stroke
2690.......350.......forged..medium journal...3.48" stroke
3279.......302.......forged..medium journal...3.00" stroke
3474.......283.......forged..small journal....3.00" stroke, military tank use
4577.......327.......forged..small journal....3.25" stroke
4672.......327.......forged..medium journal...3.25" stroke
310514.....350.......cast....medium journal...3.48" stroke
330550.....350.......cast....medium journal...3.48" stroke
354431.....262.......cast....medium journal...3.10" stroke
3727449....283.......forged..small journal....3.00" stroke
3729449....265.......forged..small journal....3.00" stroke
3734627....327.......forged..small journal....3.25" stroke
3735236....265,283...forged..small journal....3.00" stroke
3735263....283.......forged..small journal....3.00" stroke
3782680....327.......forged..small journal....3.25" stroke
3814671....327.......forged..small journal....3.25" stroke
3815822..265,283,302.forged..small journal....3.00" stroke
3835236....283.......forged..small journal....3.00" stroke
3836266....283.......forged..small journal....3.00" stroke
3848847....283.forged or cast..sm. journal....3.00" stroke
3849847....283.......forged..small journal....3.00" stroke
3876764....283.forged or cast..sm. journal....3.00" stroke
3876768....283.......forged..small journal....3.00" stroke
3884577....327.......forged..small journal....3.25" stroke
3892690....350.......forged..medium journal...3.48" stroke
3911001....307,327...cast....medium journal...3.25" stroke
3911011....307,327...cast....medium journal...3.25" stroke
3914672....327.......forged..medium journal...3.25" stroke
3923279....302.......forged..medium journal...3.00" stroke
3932442..267,305,350..cast...medium journal...3.48" stroke
3941174....307,327...cast....medium journal...3.25" stroke
3941178....302.......forged..medium journal...3.00" stroke
3941182....350.......forged..medium journal...3.48" stroke
3941188....350.......forged..medium journal...3.48" stroke
3949847....283..forged or cast..sm. journal...3.00" stroke
3951130....327.......forged..medium journal...3.25" stroke
3951529....400.......cast....large journal....3.75" stroke
SBC ONE PIECE REAR MAIN OIL SEAL
10168568...265.......cast....medium journal...3.00" stroke
12552215...364.......cast....medium journal...3.62" stroke, Gen. III, 6.0L
12552216...325,350,364.......cast....medium journal...3.62" stroke, Gen. III 5.7L LS1, 5.3L, 6.0L
12553312...293.......cast....medium journal, 3.27" stroke, Gen. III, 4.8L
12553482...293.......cast....medium journal, 3.27" stroke, Gen. III, 4.8L
14088526...305,350...cast....medium journal...3.48" stroke
14088532...350.......forged..medium journal...3.48" stroke
14088535...305,350...cast....medium journal...3.48" stroke
14088552...350.......forged..medium journal...3.48" stroke
and if your going to drop $1500 on a BARE BLOCK your probably going to want to try to insure it doesn,t get cracked when a cheap cast crank fails so an ALL FORGED AND BALLANCED ROTATING ASSEMBLY is a good idea.
